New & Noteworthy
High-Speed Vacuum Pump
Image courtesy of Pfeiffer Vacuum
With pumping speeds ranging from 80 to 800 liters per second, the HiCube Neo vacuum pumping station is ideal for demanding high vacuum and ultra-high vacuum applications. The station can be prepared for wide-ranging applications with an array of different backing pumps, such as diaphragm, rotary vane, scroll and multi-stage Roots pumps. Typical uses range from analyzing gases and calibrating vacuum gauges to pumping down cryostats and use in vacuum furnaces.
Features include a 7-inch touch screen, remote control via a web server, and detailed data recording. Its open design facilitates maintenance and allows easier access to the components. The backing pump’s energy-efficient standby mode also reduces energy use and cuts operating costs.
See this company at The ASSEMBLY Show Oct. 22-24 in Rosemont, IL.
Pfeiffer Vacuum
pfeiffer-vacuum.com
