Remote visual inspection (RVI) is a nondestructive testing (NDT) technique used for the visual inspection of an object where the person performing the inspection operates a piece of equipment from a distance. Most of the inspection applications used for quality purposes are carried out using three main types of equipment: borescopes, unmanned aerial vehicles (UAV), and crawler robots. Find out more about their uses and advantages.
Digital radiography is the future. Read about the most common modalities, computed radiography (CR) and digital detector array (DDA) radiography, that are replacing traditional film-based inspections.
As additive manufacturing (AM) applications are more widely adopted, processes and material specifications, testing and inspection requirements are all gaining importance.
The pandemic has turned the global supply chain on its head. Manufacturers of materials and finished items are under unprecedented pressure to manage a disrupted workforce, while responding to ever-changing customer demands, in many cases with profound urgency. It’s enough to make one’s head spin.
The days when only large companies could adopt automation are long past. Collaborative robots (cobots), lightweight industrial robot arms (LIRAs) and affordable peripherals such as vision systems and grippers have created a new paradigm by making low cost, easy to use automation solutions available to small-to-medium sized companies for the first time.
Vision guided robotics (VGR) is an automation technology well-recognized for enabling greater flexibility and higher productivity in a diverse set of manufacturing tasks over a wide range of industries.
If January is the month of resolutions, April is the month of renewals, a time of spring cleaning. Like people, businesses of all sizes undergo a similar ritual. Instead of tackling overstuffed closets, C-suite executives update their quarterly economic forecasts and prepare for the second half of the year.
