WEST CHESTER, OH-Ohio Governor Ted Strickland awarded the highest honor in exporting for 2007 to Marathon Sensors Inc., a designer, manufacturer and marketer of atmosphere sensors, instrumentation and control systems
ANN ARBOR, MI-The Automated Imaging Association (AIA) promoted Dana Whalls to managing director. Whalls has more than 18 years’ experience in marketing, business development and finance in metropolitan Detroit-area advertising
ORLANDO, FL-The AIA board of directors elected Michael Cyros, president of Allied Vision Technologies Inc., as AIA president for 2008. He succeeds John Merva, who served as president for three
ORLANDO, FL-Don W. Cochran, chairman and CEO of Pressco Technology Inc., was presented with the 2008 Automated Imaging Achievement Award during a ceremony held at the Automated Imaging Association’s (AIA)
For years, the machine-vision market has been dominated by analog cameras that require interfaces to convert signals from analog to digital and back again, and the frame grabbers that capture the frame and store it as a digital file. But, the market is changing.
The Prox Light comes with a Light One 5-watt high-current LED 24VDC, 30-millimeter barrel sensor housing and constant current driver. The unit also has a built-in strobe NPN/PNP trigger control, intensity control/internal pot or 0 through 10 VDC analog signal and three filters-thin file, opaque and polizer. The unit will work with any M12-5 pin connector, and will mount with any 30-millimeter barrel bracket.
IPD VA3X vision appliances provide quick setup, factory-friendly wiring and support for one or two cameras with choice of sensor resolution. Available in two versions, the VA3X offers operators choice and flexibility to satisfy their near and long-term application needs. The VA30 comes with iNspect software, while the sister VA31 version includes Sherlock. The vision appliances can be positioned alongside other automation controllers, with the benefit of small camera heads for easy mounting. The dual camera capability of the product also provides significant cost savings in multi-camera applications. The units have industrial grade I/O and external connections located on the front, and include status lights for every input and output connection to help application debugging. On the sensor side, the VA3X provides operators with many resolution choices, from presence and absence to high-precision measurements. Standard supported sensor resolutions are 640 by 480 and 1024 by 768; however, higher resolutions to 1600 by 1200 are possible.
The GC750 Gigabit Ethernet camera connects directly to the Gigabit Ethernet port on the host computer and does not require a frame grabber. The result is a low-cost alternative to analog camera/frame grabber options. The camera incorporates a scan CMOS sensor with global electronic shutter suitable for capturing high-speed motion events. The CMOS sensor used in the GC750 has excellent near IR sensitivity. The camera runs 60 frames per second at 752 by 480 resolution via a GigE Vision-compliant Gigabit Ethernet interface. The camera is available in both monochrome and color models supporting both 8- and 10-bit formats. The color version of the camera outputs fully interpolated RGB as well as Bayer 8, Bayer 16, YUV411, YUV422 and YUV444 image data. The GC750 includes external trigger and sync I/O, and an RS232 port for controlling peripheral devices. It also includes auto-iris control output for video-type auto-iris lenses.
Having a narrowly focused light beam, the Series 0507 of miniature rectangular sensors detects objects through holes and gaps, as well as closely lined-up or laterally approaching objects with distances that cannot be kept constant. The series is characterized by the small size of the sensors (5 by 7 millimeters), with a housing length of 40 millimeters. The spherical sapphire lens is scratch resistant and projects a virtually cylindrical light beam with a diameter of less than 4 millimeters, permitting vertical as well as horizontal mounting. The devices are short-circuit proof and operate in a voltage range of 10 to 30 VDC, and with an output current of up to 100 milliamperes. They are fully vacuum potted and, therefore, largely insensitive to environmental influences (IP 67).
Contrinex Inc. (866) 289-2899 www.contrinex.com Reply 696
