The Ultraprobe 3,000 ultrasonic leak detection system can be used to detect leaking valves in hydraulic systems; faulty bearings in motors, pumps and gears; and examine cabin pressure and cockpit window leaks in aircraft.
The XL Go VideoProbe is a high-resolution video borescope. Applications include the inspection of windmills, pipelines, gas turbines, steam turbines, aircraft engines, automotive engines, steam generators and heat exchangers.
The Armanda is a multi-technology, X-Y robotic arm designed to perform nondestructive assessments of metallic and composite structures for military and civil aerospace industries.
The MagnaRay is a wavelength dispersive X-ray spectrometer (WDS) that automatically combines energy dispersive spectroscopy (EDS) results with WDS operations.
The BIB-150P UV lamp has been improved by replacing the metal housing with one made from an engineering polymer that is dent proof and impact resistant.
The BOD 63M time-of-flight photoelectric laser sensor can be used for applications such as error proofing in assembly, packaging, printing and metal processing.
