NDT Products
Portable Corrosion/Erosion Monitoring System
Rohrback Cosasco launched the ULTRACORR 2, the next evolution in the portable ULTRACORR Corrosion/Erosion Monitoring System which provides the highest resolution and most cost effective, direct wall thickness and temperature measurement on a pipe or vessel, using fixed Ultrasonic transducers mounted at various locations throughout a site.
The ULTRACORR 2 Ultrasonic Reader/Data-Logger is intrinsically safe and ideal for offshore, refinery or pipeline applications where direct corrosion/erosion of complex pipe geometry is desired or where monitoring locations are in areas where access may be limited. The ULTRACORR non-invasive corrosion/erosion monitoring system will complement the process corrosion/erosion information obtained from the intrusive probe technique.
After initial installation, access to the corrosion monitoring point is no longer required. The sensor will be permanently fixed to the outer pipe wall and the cable/connector can be run to a convenient location for taking thickness and temperature readings using the portable interrogator/data logger unit. These readings can then be downloaded using an IS Bluetooth hand held unit and subsequently transferred to a PC running Corrdata® II software for storage and trend analysis.
The ULTRACORR 2 sensors are Zone 1 rated for temperatures up to 302°F (150°C) and are equipped with an integral RTD temperature sensor which enables taking of simultaneous metal thickness and pipe wall temperature readings. Typical measurement time per sensors is a few seconds. The user can program the ULTRACORR 2 to collect data using an IS Zone 1 rated portable Bluetooth instrument.
Rohrback Cosasco
(562) 949-0123 ext 213
