With a background in international management and more than 15 years’ experience in the testing industry, Ronan Harkin joins Exova from LINK Engineering Company.
Environmental simulation is a critical part of the armory of product designers and manufacturers, ensuring that end-uses are viable in a whole host of complex and niche situations. In mature industries, a focus of environmental simulation testing is on pushing products and materials to ever greater resilience by upgrading and expanding measurement for more extreme ranges, increasing the resilience of products.
In 1976, the company’s first Maintenance Service Plan (MSP) was developed for operators of Honeywell-powered business and executive aircraft as a cost- and time-saving approach to engine maintenance.
These two choices for bore measurement come into play when close tolerances are the order of the day and speedy, repeatable measurements are required in a production environment. Keeping these requirements in mind, instrument makers usually offer options such as hard chromed bodies or carbide pads and contacts where needed to keep wear at a minimum.
We’ll cover some of the common problems associated with microhardness testing and address some of the techniques and technologies that can be used to avoid them.
The Vickers and Knoop microhardness testing methods have become invaluable for the testing of a variety of parts, which have what can be referred to as “shallow layer hardness.” Such characteristics as surface hardness, thin cross section, coating hardness, and case depth are measured using the microhardness testing methods. These methods also can be useful for selective testing of particular grains or constituents such as those found in powdered metal parts.
Any article on dimensional measurement will usually get around to micrometers in one form or another. This series on bore measurement is no exception even though I am only offering a brief look at the application.
Manufactured parts need to be measured to ensure they meet the original design intent. Modern manufacturing techniques allow complex parts to be made that can have numerous critical dimensions.
There is a broad spectrum of applications for portable helium leak detectors that touches numerous industry market segments. Vacuum systems as well as a wide variety of products and devices require leak testing as part of the quality testing process.
In September, the International Organization for Standardization (ISO) published ISO 9001:2015, the updated high-level system (HLS) quality management system standard that includes some fundamental changes in how organizations are expected to operate to remain in conformance.
