The MicroScribe X portable CMM features data collection with SmartCapture trigger for continuous or single-point data collection with a variety of tips; an electromechanical brake to help prevent arm damage; application-specific calibration for increased accuracy; a verification gage; and software included for accuracy self-check. The unit comes with a standard three-year warranty, and the customer chooses which third-party software to use. Re-certification procedures can be done at either an authorized center or on-site for reduced down time and no shipping risk or expense.
The 1200 Series (ASME grade 2A) pressure gages provide the capabilities necessary to monitor pressures in nearly every type of process. In basic applications, the Type 1259 is the economical choice. In more rigorous installations, the Type 1279 Duragauge pressure gage is designed for use in the presence of harsh pressure media, fire hazards or extreme cycle volumes. Add pulsation and vibration, and the Type 1279 Duragauge Plus! pressure gage offers patented technology to dampen pointer flutter without the need for liquid fill.
Turnkey inspection systems are designed and built to meet the customer’s specific inspection application, for parts as small as bolts and nuts or as large as I beams or engine blocks. These systems are often designed around eddy current-based inspection products, but also can include magnetic flux leakage technology, ultrasonic technology or vision systems, all operating together to perform a fully automated inspection process. The systems can be integrated into any manufacturing operation so there is minimum information lag between when a defect occurs and when it is detected.
The Targa III Dynamic Runout instrument measures runout on high-speed spindles at speeds up to 300,000 RPM. The new instrument has a noncontact capacitive sensor and a digital display with multiple measurement modes. The dynamic runout mode (DRO) presents a continuously updating TIR measurement that does not require manual reset when the TIR decreases. This feature allows measurement of DRO across a range of spindle speeds. Results of this test indicate the optimal speed for production operation of the spindle.
The MSV-300 Series microspectroscopy system provides transmittance/reflectance measurements of microscopic sample sites for a range of wavelengths, from the ultraviolet to the near infrared. Conventional measurements require samples with dimensions comparable to a millimeter-sized optical beam. The series can measure color, film thickness and other spectral properties of a microscopic area for either large or small samples with a minimum spatial resolution of 30 microns. The optional automated X-Y-Z stage provides multi-point or mapping measurements for surface analysis of samples. The series has a spectral measurement range that offers continuous measurements between 250 and 2,000 nanometers (MSV-370). An integrated CCD camera allows verification of the analysis site and sample position while defining the sample aperture on the software system. All microscope operations are PC-controlled through the Spectra Manager software interface.
The Glider is a manual 2-axis encoding scanner designed primarily for the inspection of composite and aluminum aircraft parts such as fuselages. The instrument has a cost-efficient design, multi-technology capability and lightweight but rugged construction. It is compatible with phased array (PA) or conventional ultrasonic (UT) probes, as well as conventional eddy current (EC) and eddy current array (ECA) probes. Both axes offer a free-running, incremental or lock mode. The standard, pivot-equipped suction cup pods enable contour following on curved surfaces while the optional magnetic mounting pods extend the versatility of this scanner to corrosion-mapping applications involving ferromagnetic materials. With a light, aluminum frame and removable index arm, the instrument can be transported or reassembled for use on multiple parts. It is available in three sizes, providing scan areas of 46 by 46 centimeters, 61 by 61 centimeters, and 91 by 91 centimeters. It will interface with the OmniScan modular flaw detector or any other data acquisition system.
The C-Arm Inspection System is for quality control imaging in the areas of casting process verification and product analysis for automotive component manufacturers. The system has an image intensifier coupled to a high-resolution high-bit-depth digital camera for real-time viewing and a programmable computer numerical controller (CNC) to manage part positioning. The system, which allows a full 30-degree angle of detection (tilt), handles scanning at obtuse angles. The system integrates into the production process and can be directly interfaced in a robotic manufacturing cell. Additional features include: image intensifier, amorphous silicon panel or LDA configuration; energy sources of 160 kilovolts, 225 kilovolts and 320 kilovolts; static or dynamic image viewing; image enhancement and archival system; a part envelope of 610 millimeters by 610 millimeters and 50-kilogram capacity; 30-degree (+ or -) tilt, 914 millimeters up/down motion; programmable or manual operation; US 21CFR1020.40, UVV, DIN54113, VDE-0-100, CE, EUATOM 96/29 and IEC 529 compliance.
The Maxima ML-3500 Series ultraviolet lamps use micro discharge light (MDL) technology, plus a unique filter and bulb/reflector, to deliver up to 10 times the UV-A (365nm) output of conventional HID inspection lamps. With these lamps, NDT inspectors can see surface defects, hydrocarbon contamination and other flaws that escape less powerful lamps. The lamps are available in 120 volts, 230 volts, 240 volts and 100-volt AC versions, as well as battery-operated versions that include a 12-volt, 7 amp/hr rechargeable battery, which will operate the lamp for two hours. A battery charger and carrying case are included.
The Model E2 leak testing instrument has a built-in Micro-Flow sensor (IGLS) and two levels of fill/balance for faster test cycles. The device allows the operator to remotely monitor leak tests over a network, using the E2 Ethernet connection and Leak–Tek program Version 5.0. The unit has a touch screen with graphical color display. The instrument is for use in pressure applications with leak rates from 0.1 cubic centimeter per minute.
The KD-2306 is a noncontact linear displacement measuring instrument based on balanced bridge eddy current technology. It makes high-precision static and dynamic measurements, and supports ambient, moderate temperature and cryogenic rated sensors. Applications range from lab work to production and process automation. The DIN rail mount packaging makes the system ideal for integration into OEM equipment and industrial control applications. The KD-2306 senses both ferrous and non-ferrous metal targets. The RoHS-compliant, CE-marked system includes the electronics, sensor and interconnecting cable. Standard sensing ranges are from 0.02 inch to 2.4 inches, with 0.01% FS resolution or better, and nonlinearity as little as 0.25% FS. More than 30 sensor models are available, including single and dual coil, shielded and unshielded designs.
