Each NDT method has its advantages and disadvantages, so knowing what your flaws of interest are and where they tend to be located can be extremely helpful.
Flaws can be found in every type of material and component, no matter the method of manufacturing, processing, or finishing used. Selecting the proper detection method is crucial, because, even if a flaw is not actually a defect, you still want to be able to detect and evaluate them.
Statistical Process Control’s impact on industry has been enormous.
June 8, 2022
Statistical Process Control’s impact on industry has been enormous. It has branched out beyond the manufacturing realm and can be applied to any process with quantifiable outputs.
Proper fixturing addresses several key parts of quality: It ensures that inspected parts remain in a repeatable and reproducible orientation on a measuring device.
A centralized quality hub should help organizations to oversee, examine, and report on data and processes from unrelated data sources in real time, creating a comprehensive vision of operations.
May 2, 2022
Quality equals reliability. The best way to attain it is through a centralized quality hub. Manufacturers can get into trouble when their quality efforts are de-centralized.
How do you select the right shop-floor CMM for your production line? Making an informed decision means understanding application needs, what solutions can meet your needs and how to “future proof” your selection.
One of the most fundamental decisions in mechanical design is selecting which material a part should be produced from. Often, a variety of factors will influence the success of a part.
To facilitate widespread adoption of AM, it will be necessary for material property data to be shared among the design community at large instead by being held by a few large companies.
In 2010 the ASTM F42 Committee on Additive Manufacturing (AM) created the terminology for an industry which up to then was referred to as rapid prototyping (RP). Parts made using the various rapid prototyping technologies were often used as design concept models, fit check mock-ups and function test articles.
Many stylus manufacturers will tell you that custom disks are the designs most often requested for custom fabrication quotes. Like handprints, it seems as though each disk stylus is unique.
Big Data, Industry 4.0, Robotics, and Machine Learning were the focus of the recent Quality Show that was held last week at the Donald E. Stephens Convention Center in Rosemont, IL.
