East meets west. It’s a common idiom that has been around for so long that it has evolved to both express agreement and collaboration as well as to describe polar opposites, and just about everything in between.
Uniformity has long been associated with quality perception, and color can be one of the most striking visual giveaways if products are inconsistent. As a result, consumers are more likely to associate these color flaws with inferior, low-quality products or brands.
When a shop begins the manufacture of rotating shafts, they frequently turn to their conventional CMM for part validation. However, this is often a case of using the tool that is at hand, rather than one designed for the job.
Understanding the different hardness testing types and systems can be useful to determine an optimal solution. Hardness testing functionality has evolved and now users can dial into world-class instrumentation which more closely aligns with their applications at hand.
If you were to ask an assembler at a Tesla factory how they measure the diameter of a piston, the response could very well be “what’s a piston?” If the same question were asked, a traditional combustion engine assembler would likely exclaim “with calipers, of course!”
Gabriel Hughes was once asked to calibrate a 2x4 at a previous job. While this may sound strange, the customer sent it in to have the precise dimensions calibrated. The wood was used to keep a door closed at a certain height, which they needed to monitor because of airflow.
In a lean manufacturing process, a poka-yoke method is employed to eliminate product defects by preventing, correcting, or drawing attention to human errors in real time. Industrial engineer Shigeo Shingo first applied the term poka-yoke (“mistake-proofing” in Japanese) to the Toyota Production System.
