Whether it’s called a compression tester, tensile tester, dual-column tester or twin-column tester, material testing machines go by many names. So, when users need to find the best machine to test their products, the market can appear to be a difficult one to navigate.
Don’t bite off more than you can chew, and really understand the methodology before attempting a large Six Sigma project. Those are the first words of advice for a Six Sigma novice from Six Sigma Master Black Belt John Vandenbemden.
Before selecting an X-ray fluorescence (XRF) analyzer, consider what you want to achieve. For example, if you are looking to confirm alloy grades for incoming goods QC, you will want to know what the important element in those grades should be.
Referees at sporting events can fuel elation or outrage with their calls when it comes to a favorite team, but in truth, these people are needed to provide an impartial interpretation of the rules of the game.
GD&T is the only tool we have with which to manage machine part geometry perfectly. In particular, it’s the only tool we have with which to impose truly functional limits of imperfection on machine part features and actually guarantee assembly and operation prior to drawing release.
It’s certainly not news that more and more gages are being forced out onto the shop floor. Tight tolerance measurements that were once performed by a trained inspection technician are now being done right next to the machining center, most likely by the machine tool operator.
There was a time when choosing a gaging solution for shaft-type parts was a relatively straightforward task. High-volume parts received a custom-built gage and everything else received a manual or automatic “snap-on” or ring gage of some sort.
